psi guage
jaybrown
Banned
I have the guage that was used for a merc has the end that scrwed into the merc block will this work on a johnson? and where would i screw it into on the block i couldn't see any spot for it?
jaybrown
Banned
Has anyone ever had a psi water guage hooked up? not a temp guage dont care about temp just want to know how much water im getting when its trimed right up
interalian
"T" fitting in the pisser line, run the hose out front (may need to drill a hole in the lower cowl), then up to the gauge. Very common.
CatTwentyTwo
What year is your 175? I have a 94 with the pressure line connected to the block.
