Antonio-88
Thread starter- Joined
- Jun 18, 2016
- 11
So after rebuilding carbs, fuel pump, replace all fuel lines, primer bulb, I replace head gasket because water was getting into the cilinders, I'm still having the same problem my boat won't plane and losses power at WOT so I was reading some troubleshooting procedures on my trigger the actual resistance whithe/black to brown is 1400 ohms, white to purple is 2600 ohms, according with the manual I should have between 800- 1400 ohms so this means my trigger is bad? Someone have and answer for this please, also when I removed the flywheel I notice I magnet is cracked
