BigBand
Thread starter- Joined
- Jun 2, 2002
- 17
I'm working on a 1996 25hp Johnson outboard that I recently bought. No stream of water coming out the tell tale.
The motor ran great on the muffs when I ran the motor before purchasing it. I got it home and finally put it on my boat. Took it to the lake and no tell tale stream.
I've just replaced the water pump and reassembled. The original impeller looked and felt pretty good, but it's cheap insurance, so I put in the new one. I didn't see anything out of the ordinary when it was apart, other than a little corrosion due to limited salt water use. While I had the lower unit off, I put compressed air up into the water tube (water pump outlet tube) and I could hear it coming out of the tell tale. After reassembly, I ran the motor on the muffs again, and it still won't pee!
I think I need to divide and conquer, so I'm wondering how I can test the water pump. If I submerge the lower unit in a bucket of water so the water inlet is under water, wouldn't it work to turn the drive shaft with an electric drill and see if water is shooting up out of the water tube?
If this works, what else could it be? The schematic drawings show the tell tale in front of the thermostat, so that shouldn't be an issue. I doubt there's enough corrosion that water passages would be clogged, but I suppose that's a possibility. I've heard of a corrosion cleaning solution I could use - anyone know anything about it?
I need some net.wisdom !
