To follow up on this . . .
First, I am actually surprised no one pointed out how painfully easy it is to check water pump flow by removing the thermostats. In the event someone else visits this thread looking for help with an over heating problem, here is what I did.
First, I had a pee stream, so I knew my pump was a least partially working. If you do not have a stream, then you may need to start elsewhere. Might be blockage, might be pump.
The two thermostats are very easy to get at - literally sticking out of the back of each cylinder bank. Open both and remove the thermostat and hand tighten the thermostat covers back on. Start the engine and one at a time remove the thermostat cover. At idle, water should have a slow, but even flow out. I can't think of anything to adequately compare the flow to, but remember it is at idle, and the pump is turning slowly, not to mention with both thermostats out, there is no mechanical restriction. After checking one side, close it up and check the other. This will check both flow and for any evidence of blockage in one bank or the other by comparing what you saw on one side to what you see on the other. In my case, I had good flow from both. I need to restate that this is at idle, so it will not gush like from a fire hose, but more like pouring water from a glass.
Now that I determined my water pump had not failed, it was time to move on to checking the thermostats themselves. In a series of very easy things, this was no different. I took a cereal bowl and filled it with water and microwaved it for 5 minutes. Then, drop the thermostats in the water and watch them (hopefully) do their thing. They should begin to open, albeit slowly, almost immediately. I had a new one for comparison and threw it in there as well. They don't open far, because they are obviously little things, not like the large auto thermostat you think about at first. At full open, they have really only opened about a 1/4" to 3/8". However, they should be full open in water that hot withing 10 to 15 seconds. In my case I had one that barely opened and the other opened, but I thought a bit slow. I ended up replacing both.
Buttoned it back up and took it for a spin - - All good. Problem solved.
