warrenfine
Thread starter- Joined
- Mar 19, 2006
- 28
I HAVE A '95 MALIBU RESPONSE, HAS THE 350 MAGNUM EFI S/N 349443 RUNS OKAY WHEN COLD FOR ABOUT 5 MIN. AFTER A FEW MIN IT STARTS TO CUT OUT ABOVE 3000 REV IT THEN GETS WORSE, CUTTING OUT AT LOWER RMP. SOMETIMES YOU CAN DRIVE FOR AGES AS LONG AS I KEEP UNDER 3000 REV BUT OTHER TIMES IT CUTS OUT AT LOWER REVS.<br />IF YOU LET IT STAND FOR A WHILE IT RUNS OKAY FOR A BIT THEN STARTS CUTTING OUT - IF I PULL BACK THE THROTTLE IT GOES AT THE LOWER RMP.<br /><br />I HAVE CHECKED ALL BASICS - FUEL LINES NEW PRIMARY FUEL PUMP, TANK VALVE, HIGH PREASURE FUEL PUMP STRAINER. I AM LEANING TOWARDS ONE OF THE SENSORS - I AM COMPLETELY STUMPED - PLS HELP<br /><br />WARREN
