1985 omc stringer shifter cable install
Status
Not open for further replies.
pg welding
i have a 1985 stringer i just can't figure out how to install cable in lower unit
whywhyzed
Banned
Re: 1985 omc stringer shifter cable install
The small puck runs UNDER the idler pulley...<br /><br />The procedure in the manual is approx. 2000 words and has 4 or 5 diagrams... I'm a slow typer..I would buy a manual before attempting that procedure.
pg welding
i have a manual. i rebuilt the upper and lower and have a clue but this one is kicking my but
DHPMARINE
Wow,I haven't done one of those in years.Now won't even work on them.BUT I do remember having to re-read that manual many times to understand what it was telling me.<br /><br />I think the main problem I had was after the pucks were in the spools,having the 'rack' in the right position when engaging the cable and cover.<br /><br />Do you have to remove a spool to install the cables ? I don't think so,but I used to have a tool (home built) to do that.Probably to reseal the shaft the spool was on.It's been a while.<br /><br />DHP
pg welding
thats it my problem (is) setting up the rack in the right position. There must be a trick i just can't get it to work right
DHPMARINE
I thought someone else whould jump in,but it hasn't happened.<br /><br />OK ...... can you pull the rack up and engage forward?<br /><br />Now set the cover AND cables over it,and bolt the cover down.This may set everything into neutral, and you'll be okay.The rack has to move down as the cover gets bolted down.<br /><br />DHP
T_I_M
Yes you do,and after you remove it ( yes there is a special tool )and install the new cable you have to twist it 180'.I don't have the manual here but I will look at it tomorrow and reply .I've done a few of those and they still catch me .
KaGee
DHP,<br /><br />I sent him copies of the OMC manual. Haven't heard back from him.
blacknite30
Hello,
Can you please e-mail a copy of those instructions too.
Thanks!
Status
