93 evinrude 150 hp spitfire lower
Gonefishing85
I got this motor with the lower pulled off. The lower got a hole in it and ended up seizing all the bearings. I was going to patch the hole and replace the bearings but there are a lot of other odds and ends missing and it's going to cost me as much as just replacing the lower. I need to know what other lowers will cross over.
Gonefishing85
I know there is a interchange chart but I don't see my year/model
boobie
Try the top secret file at the beginning of this forum.
boobie
I just went and looked and your motor is in there with the years.
SEI likely makes a new replacement for about the cost of a used unit.
Faztbullet
Any v-6 lower unit with 1:87 ratio from 1992 to 2000 will fit, all you need to do is install your driveshaft...
Gonefishing85
Perfect. I've heard that the v4 lowers will fit also but have a different gear ratio. I have the gears also. Will they fit in the v4 lu?
boobie
The Top Secret File is at the top of the very beginning of this forum. Look Again.
Gonefishing85
I'm no genius but this is what you all keep referencing and I don't see any 1993 150hp listing.
85-140.............(crossflow 13 spline prop shaft).............1978-1991
88-140.............(crossflow 13 spline prop shaft)..............1992-1998
120-140 Looper V-4... (15 spline prop shaft)...................1985-1991
75-115 60 degree........(bat wing unit 13 spline)...............1995-2006
150-235 & 2.6.................(crossflow V-6)......................1979-1991
185-225.........................(Looper V-6).........................1986-1991
185-225....................(Looper V-6 & Ficht)....................1991-2005
150-250.......................( Magnum Series).....................2002-2007
150-250........................(Lighting Series)......................1997-2001
Faztbullet
What type of gears do you have and no V-6 gears will not fit a V-4 housing...
Gonefishing85
The gears in the lower. The lower was intact minus water pump and associated hardware. I'd imagine the gears are all whatever was standard on this motor. I was just going to patch the hole and replace bearings but during disassembly my parts list quickly grew to over a grand worth of parts. Basically the housing, shafts and gears are the only salvageable items. Sadly this is the cleanest 1993 outboard I have ever seen and the power head is entirely rebuilt and pristine. I just need an affordable lower.
Gonefishing85
What I don't understand is why an entire outboard with a blown motor can be found for 200-400 including lower, but then a stand alone lower is a grand or more.
Gee, check with SEI, There new gearcases will be lower than that.
interalian
Then buy the entire blown motor, take the gearcase and scrap the rest. Or even keep a few of the other accessory parts to have as spares - ignition stuff, carbs...
Gonefishing85
Well that's the plan and why I need to know what lowers will work
Gonefishing85
I spoke to a local dealer and they said any v6 lower from 1979 to 2010 will work. Sounds fishy.
