jimmbo
- May 24, 2004
- 14,646
Once again, my personal opinion only. A transom saver does firmly hold the engine and the transom solidly with the trailer when used. The mere fact that even little bouncing while trailering does eventually work on the transom. And that can be stopped using a transom saver. Any time you can stop any movement, you stop any stress cracking as well. Regardless the material, stress will eventually win out over the years. But again, this is just my opinion and by no means contradicting anybody else's.
The saver works when the engine or outdrive can move even the tiniest amount, but if the engine and drive are rigidly locked and a so called transom save is used even the tiniest movement of the boat in relation to the trailer, now places all kinds of stress on the transom leading to stress cracking. If the boat can be made to never shift even the slightest on the trailer, then and only then, would I consider the Transom Saver safe. Just my Opinion
