Help with motor identification!
98SkeeterSS90
135psi on all 4 cylinders on compression. Will test the spark when I get an adjustable tester.
Will look for more identifying markers as requested as soon as I can.
98SkeeterSS90
Trim/tilt is 3 wire, I can see where it used to be two wire and it's been snipped off and three wires are ran now. They run straight to the battery and switch on the gear shifter. I don't see any relays or relay box.
Carb kits will be here tomorrow, got bottom carb squeaky clean soaking top now will make sure they are both super clean. Hopefully I'll have it running this weekend.
I don't see any any omc embossed letters ahead of the skeg (if I'm looking in the right spot)
emdsapmgr
You need to have the power trim relay box in order for the 3-wire trim system to last. If it's missing, it's possible that the P.O. has wired the "up" movement direct through the switch in the control box handle. If so, won't be long before the switch goes kaput. The up movement current needs to go through the single relay, which was part of the 3-wire system diagram. The up part of the switch will burn out soon, as it tries to handle all the current required to push the trim rearward. Check out the original factory parts diagram at the factory parts website: epc.brp.com
98SkeeterSS90
Thanks for that link! Will come in handy for sure
