New owner, old problems
VikkiP
I recently inherited, for a reasonable fee, a 1951 TN 26 that belonged to my cousin's grandfather. Last time he can recall it running was c. 1967 and I believe that is probably accurate. I don't have a boat (I do have one I can borrow that would be suitable) and I have no experience with boats or motors but I love vintage machinery, have some experience with old two stroke motorcycles, and want to put this little thumper back on the water where it belongs.
I have removed the fuel tank, which was dry and covered with lead oxides inside and grease/oil/dirt outside. The tank is soaking now after removing the fuel tap, which is solidly gummed up. The carb is frightful. I removed the fuel line and very thick oil, thicker than 90w, is slowly dripping out and I'll remove the carb later once I set up a suitable drainage location. I am sure I will need to obtain seals but I am looking for a basic carb rebuild guide to make it easy.
The only physical damage beyond scuffs and scrapes is the tiller handle. The rubber grip is broken and a heavy spring is exposed. I'm not sure if there is supposed to be more to it, or if it just needs a new grip. There is a little tube taped on with shear pins, nothing broken there.
Water pumps are new to me, the two strokes I work on are all air cooled so I am not sure what I need to know about cooling on this motor.
I'd also like recommendations on the most suitable two stroke oil, spark plug, and gearcase oil for this motor. I've searched this forum and found old threads about carb seals but I'm also looking for other tips and tricks to bring this old beauty back to life. I just want it lakeworthy, I'll save cosmetic restoration for post-retirement.
Thanks in advance,
VikkiP
I've safely removed the carburetor. It's completely varnished. Is there supposed to be an air cleaner or filter? There isn't. In the small chamber right behind the throttle plate, on the bottom, is an open hole that looks like a small screw hole. Is it supposed to be open? It looks like it is the source of all the fuel residue on the powerhead.
How does one remove the screws from the bottom of the bowl safely? They are varnished in place very well.
How does the float come out without damaging it or the needle?
VikkiP
http://www.boatinfo.no/lib/johnson/manuals/1922-1964johnson.html#/0
this should have answers to all your questions, and then some
Thank you. While I didn't find answers to what is recommended today, nor how to remove seriously stuck screws (I eventually got them all without damage), I did learn that the hole in question is an overflow drain and the fact that it was spewing fuel confirms that the carb needed attention before it was put away.
The cork float is still in great shape but is covered in sticky residue. Once clean, is there anything else I should do to prepare it for reuse?
The slow speed needle has quite a bit of fuel circuit in an inaccessible area. Is there a good way to clean it safely? The manual only mentions backing the slow speed screw out and pressing the prime button to clear the slow speed circuit but this is far beyond that in cleaning needs.
robstead
If you clean that cork float off many people suggest model airplane dope to recover the cork, if that's not available nearby to you there are other substitutes you can look up.
VikkiP
There is a model shop not too far off. As long as it's safe with today's garbage fuels then that's the path I will take. Thanks!
VikkiP
The cork is more decomposed than I thought. I'll be replacing it. The primer leathers are in good shape as they were submerged in oil but as they're more than 60 years old I'll replace them as well.
The float pin has a little bit of grooving around it, but if inverted it does make an airtight seal. Are replacement pins available?
VikkiP
I see that the brass cylinder for the primer is missing. Does anyone know of a source for a spare?
VikkiP
It's just about back together. I went through everything but the cylinders. Hoping to get it in a water tank sometime in the next few days!
VikkiP
It's running. Still needs some tuning. I am running the recommended 16:1 with TC-W3 in unleaded regular and it smokes like a chimney and seems to run lean under load.
