General CDI electric question
thatone123
Banned
When you read in the CDI troubleshooting guides to disconnect wires from coils or CDI unit lets say on a typical OMC 9.9/15 common outboard, how are you suppose to do that when the wires are molded into the units? Also, what do they mean by go from the brown wire to brown and yellow when is it not the same wire, which it appears it is?
jakedaawg
Let's do this a different way. Tell us what model motor you have and which ignition component you are trying to test.
Many times you are separating said components at the connector that leads to them and using jumper wires to test. Or test fittings designed or modified to plug into said components. Only seldom would you want to back probe into a fitting to get a reading.
Also, sometimes colors fade with age. Experience, and good wiring diagrams found in manuals help us determine which wires we are testing. Many people are here to help. The more detailed the question, the more detailed and easy to follow the answers can be.
F_R
If when you say molded units, you mean the wire disconnect plugs, the pins can be removed from the rubber plugs (you are supposed to use a special tool to do it). Another way if you were seriously into doing this kind of stuff would be to have special adapter plugs that allow you to access the circuit without removing the pins.
I don't understand the second part of your question. Aren't the brown and brown/yellow wires the two charge coil leads going to the power pack?
