Johnson 30hp Rough Starts
BurninHot
Older (80s-90s) Johnson 30 HP. It has a hard time starting when cold. The bowl is always empty and I have to reprime. Then choke 4 times and it starts up but will not stay running without playing with the choke till it warms up and will rev all the way up. Then it will idle all the way down and run fine. I've cleaned the carb and plugs multiple times and idle screw is adjusted properly. Everytime I clean the plugs they're coated in oil but I run it 50:1, 3gal 8oz. Anyways to smooth this up?
BurninHot
Could it be a bad hose from the tank to the engine that makes it hard to pull a vacuum. It doesn't shut off once it's pulling and has been warmed up just in the initial phase.
Chinewalker
You said you "choke it four times". What, exactly, do you mean by that? 30s of your motor's era don't have a choke, rather they have a primer system that requires the motor to be either turning over or running to work. Simply pushing the key in without turning the key does nothing. The primer is simply a valve that opens when you turn the key in. Pressurized fuel from the fuel pump is diverted through that valve into the manifold to enrichen the mix for cold starts.
BurninHot
The front of my motor has a kill switch and a "choke" that slides in and out. Goes from the bowl of the carb to the motor. My terminology is definitely off I'm not a book guy. As far as the starting procedure, after cleaning the plugs, I fill the carb from the tank with the primer bulb, and then I "choke" or "prime" at the motor and pull the cord till she fires. Then in order to keep it running I have to continue to prime at the motor until it is pulling enough fuel to rev all the way up, about 2 min. Bare with me on this, I'm not exactly a boat guy and most of my engine knowledge is from forums like such and hearsay.
jakedaawg
K. Need a model #
When you say prime till it gets full rpm do you mean you are squeezing the bulb or pulling out on the choke lever. ?
Let's get some terms straight:
Crank means pulling hard on the rope start and getting it to turn over. Start means it's running
Prime means squeezing the bulb til firm. Or squeezing the bulb while running.
Choke means pulling outthe black handle on the cowl.
BurninHot
I mean, I am choking till it gets to full rpm. Pulling out when it bogs push back in when it revs back up. I thought I was talking about the choke but chinewalker said I didn't have a choke and I was just trying to explain to be the most understandable. As far as model number, I'll have to get back to you. I leave it in the river and it's 1 1/2 hours away.
Chinewalker
Okay, you have a manual start motor. Yours DOES have a primer. My bad, for assuming it was an electric start motor.
BurninHot
No problem at all. I just want everybody on the same page and try to smooth this up. It makes running bank poles and fishing irritating and a bother to other boaters.
Bosunsmate
coated in oil will always make for hard starting. Have you checked your motors air intakes not blocked. Sometimes they are under the handle in the cowling.
have you checked your spark is jumping a 7/16 gap or is the voltage starting too fail
BurninHot
I will check the air intake. Maybe a mouse nested in there or something. The plugs get cleaned every weekend. They are about a year old with weekend use. Could be time for a new set tho.
BurninHot
Air intake is clear. Pulled the carb and plugs cleaned thoroughly and readjusted the jets. Also replace primer bulb and line with a fresh tank of gas. Problem solved.Don't know which fixed it but I'm happy.
Bosunsmate
Quite possibly all the above added up to the rough issue. Good job
