1995 90 HP force motor wot plrobles
Antonio-88
So I have a 1995 90hp force motor it idles prefect I just replaced stator new spark plugs rebuilt carbs sink and link my carbs set timing and all that stuff, but here is the problem at wot I lose power and and o dnt gain speed and some times the motor dies I put back on idle and perfect the problem is at wot please help I dnt have idea wat else could be wrong with it
Jiggz
There is a good possibility the timing is too advance when placed at WOT. Have you tried verifying the timing after you replaced the stator?
jerryjerry05
Why'd you replace the stator??
Sounds more like a fuel delivery problem.
Only at WOT. could be the hoses are bad, the tank vent clogged, bad squeezie, inline connector sucking air.
Do a compression and spark test.
Rebuild the fuel pump.
Replace the fuel filter.
How'd you set the timing and why?
Usually the timing doesn't change unless you change things.
Antonio-88
I replaced stator because I lost spark on all my spark plugs I did check resistance with my meter en it was no resistance on the low speed coils that was the reason to replace ir
