1963 Evinrude 75HP #75352
joesn68
After finally getting the registration figured out with the help of my Insurance company I am legal to be on the water with my boat. I now have the issue of the motor not running properly, As long as I continuously add fuel/oil mixture to the carb it will stay running. Fuel bulb pumps up and stays hard but I feel no fuel is actually being delivered to the floats. I do not have a history on the motor, I am thinking that fuel deliver is not happening. How difficult are these to tear down the carb and fuel pump and clean? All tips and suggestions are much appreciated!
F_R
Pretty simple carburetor and fuel pump. Repair kits are available here at iboats. One caution: Do not remove the venturis from the carb unless absolutely necessary. You are supposed to use a special tool to align them when you put them back. Of course there is no way of knowing how many people have already installed them off-center over the last 50 years. It will run that way, but maybe not as well.
joesn68
So, do not separate the throttle body from the float chamber? Are there any ways to fabricate the "special" tool to center the venture? I will be ordering the carb kit and the pump kit from Iboats.
F_R
No Title
No, I didn't say that. I said don't remove the two venturis. When the top is off the carburetor, you will see them. They are above the two throats or barrels as in two-barrel carburetor. I don't know how hard it would be to find a centering tool. Here is one I made for a guy several years ago.
F_R
I just checked, there is one on e-bay for 20 bucks. No way in hades would I make one for that.
joesn68
yeah. that looks to be a considerable PITA. I will clean it to the best of my ability with cleaner and compressed air.
