1998 evinrude vro 70hp beeping
largyhunter27
Hi there, was out on the lake today. While running back to the ramp the ignition started a constant beeping. I'm assuming it is an alarm of some sort. I was in some pretty dirty water earlier in the day, with some vegetation etc. I did turn it off and restart it. It was still there for a minute or two then went away. Is this normal or something I need to check out? It has a new thermostat etc. thanks
James R
Two initial checks. One is the motor overheating. You should be able to hold your hand on any part of the motor and not feel forced to remove it. Two do you have oil in the tank. If you were in heavy vegetation your water intake could have been blocked. Turning off the motor could have dislodged the obstruction.
largyhunter27
Forgot to mention in my first post that I have the vro by-passed and mix 50:1. I'm hoping just something blocking the intake as I just spent quite a bit on servicing the motor. I will see next weekend when I get it out again and try placing my hand on the cowling after a good run. Thx
flyingscott
Overheat is a solid tone how long ago was the VRO bypassed and was the pump unplugged
When you get the solid beep it is time to STOP running the motor.----A compression test may be good thing to do now.
largyhunter27
Ok will do. It was very choppy and it did sound like the motor may have came out of the water for a split second a couple of times. Could this have caused that? I am new to boating, always been a passenger before. Thanks
