2006 Tahoe Q6S with a MerCruiser 5.0L - Serno: 0W380250
Started it up today after troubleshooting a "click no start or crank" problem. Replaced Starter, block fuse, circuit breaker, and slave solenoid. Cleaned all electrical connection on the starter circuit and anything connected to battery.
Ran for about 2 minutes with ear muffs, and noticed something leaking from transom drain hole, looked in the engine compartment and saw oil leaking from the oil filter, and thought it might just be a loose oil filter. I did just change the oil and filter. Upon further investigation I saw that the oil was leaking directly ABOVE the oil filter, from what appeared to be the oil pressure sensor, although there are multiple electrical connections there.
I was curious if one is more prone to breaking, and how difficult it is to replace the sender unit and oil pressure switch. Which components should I replace if I'm changing them out? Reviewing the link attached, I'm not real sure which I should be ordering.
Thanks in advance for your assistance and guidance.
