MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
A buddy of mine has a boat that HAD a Johnson 140 model #J140TLCRD and he's replacing it with an Evinrude 140943R. My searches indicate the Johnson was a 1984, which I believe is the same as year of boat and that the Evinrude he bought to replace it with is a 1979.
The Johnson basically got shelled when it lost a ring, but on tear down we labeled everything, because we were hoping to salvage it. He came across what he;'s hoping was a good deal on the Evinrude, so he picked it up and so far he has it mounted on the boat and has been hooking up the electrics. Supposedly he heard it run before buying, but he's eager to compression test it and so forth. The problem is there is a 5 pin wire harness coming from the boat side that he can't find a place for it on the Envinrude engine. We had labeled it 'C' on tear down, so I told him to find his old parts and see what is labeled 'C'....he says it's a power pack or something. He's supposed to bring it over later, but until that time....does anyone have any idea what he should do with this wire if there is no where to hook it up? I stopped and looked at it and it comes in with all the other harness wires and stretches back towards the rear of the powerhead. I've looked through pics I took when I helped him strip the Johnson down, but so far I'm not sure what plug I'm looking for.
At this point he's planning on using the Johnson Controls, is that possible? Any clue what might have been on a 1984 Johnson 140hp that wasn't on a 1979 Evinrude 140hp.
Any suggestions going forward?
