Hi,
I have a Johnson 35 hp 3 cyl year 2000 BJ35EL3SSB motor that are having starting problem.
I have done a lot of investigation such as cleaned the carburators, filters, sparks...
I have finally found out that the problem seems to be with the electric primer/ solenoid.
I have ohm meetered it it it seams ok, but I dont know if it works fine.
Heres what I found out:
If I put the red lever on the solenoid into "manual" mode, 7 a clock, the engine starts fine, but when potting in the gear it will only run on
2 cylinders or flood when accelerating since it gets to much petrol I believe. The first spark (counting from bottom) gets all wet.
If I put the red lever into "auto" mode, thats 12 o clock it wont start at all. I can only start it if I use start gas.
If I put the red lever in "manual" mode, start the engine put in a gear, push for more gas and then switch the red lever to "auto" 12 o clock, it works just perfect, runs on all 3 cylinders and I get all the 35 hp power out of the engine. The sparks looks fine on all thre cylinders. But If I lower the gas to neutral and keeps the red lever in 12 o clock the engine stops...
So the engine needs to be in "manual" mode for starting it and in "auto" mode when running with full throttle.
So the problem could be that the solenoid is not working allright anyway. How do I test it?
If the problem is on the throttle control box, witch it might be, that is when pushing the key it does not activate the solenoid, but then
the engine should run when I got it started from "manual" mode and switch into "auto" mode and not stop, or?
I'm very greatful for any tips on this issue, I'm close to solve it but I need help on this last things.
Regards
Andreas
Regards
Andreas
