Slice of Life
Thread starter- Joined
- Apr 2, 2013
- 78
When getting ready for the water and before running the engine on muffs, I notice that the power steering pump is completely empty and dry. I look in the bilge and see a bit of red colored fluid in the bilge. So I put just a little bit of fluid back into the pump and it seems to stay in. A few days later, without running the engine, the there is more fluid in the bilge and just a bit less in the pump. The leak is slow, but definitely there. I put my hand under and around the pump, and the line that comes out the pump, and it is all dry. I put my hand on the power steering pump cooler, and it's definitely wet with fluid. I can't tell what part is leaking though, it's almost like you have to pull the engine to get to the cooler it's so far down there in such a tight space.
Would a faulty or leaking cooler explain insufficient water going through the cooling system and out the exhaust? It doesn't seem like it's leaking water when run but I will check again when I run the engine. When ran last time on muffs, there was just a small line of water coming out of the exhaust relief ports instead of the larger amount of water that usually comes out.
