Marcel Cloutier
Thread starter- Joined
- May 14, 2016
- 14
Hello everyone,
I have a 1999 40hp Tracker Pro Series by Mercury (SN 0G770127) which has been sitting for the past 2 years. I have finally gotten it running (carb cleaned, fuel pump rebuilt, new fuel filter and new bulb) however now I am having an issue with a certain fuel connector that is breaking.
It is a 90 degree connector (Part# 43335 or 433351) made of nylon. It screws directly into the side of the motor and connects a line to the fuel pump. The nipple going into the fuel line is breaking off. When it first happened I thought, old motor= old part. I replaced it and after about 2 minutes of running it happened again with the brand new part. I have also noticed both times that the fuel line (4.25") between the pump and motor gets extremely hot (can't touch it) and I think it is melting the nylon causing the part to break.
Now, for the questions...
1. Does anyone know why this is happening? Water is running through the engine according to the tell-tale. I don't know if it should be getting that hot or not but before I keep melting parts at $5.00 a piece I figured I would ask first.
2. Does anyone know where I can get the same part in metal? I have never been a fan of plastic parts on any machine, except Glock.
I'll start with this, it will probably lead to more questions. Thank you in advance for any help you can give me.
