PQvyper340
- Mar 11, 2015
- 6
Long story here but really need help...So frustrated I'm ready to light my boat on fire. Anyways, twin 496 HO's, Bravo 1x drives. Removed engines last fall to do maintenance replace the water heater (had to remove the engines to get to it). I did remove couplers/flywheels on both engines in order to mount them on stands. Noticed that the center stringer and lower bulkhead were rotted. Took to a fiberglass shop and had that all fixed/replace. They replaced the center stringer and lower bulkhead. Now, I'm putting the engines back in. Got the port engine in and aligned perfectly. Now on to the starboard engine. Got that in and can get it aligned perfectly but then when I rotate the crankshaft in 90 degree increments it is WAY off. So, I pulled the engine again and installed a new coupler. I can get the alignment perfect, but then when I rotate the crankshaft 90/180/270 it is way off. I followed the procedure for installing the coupler per the merc service bulletin. I then pulled the engine back out again and checked the runout on the flywheel and it is within spec. Checked runout on crankshaft where the flywheel mounts and the most I got was 0.0015. I also checked the runout on the coupler where the steel hub sticks out and the most I got was 0.005. I'm just so confused about this......
