- May 1, 2016
- 5
Hi everyone I definitely have one for you guys. I have a 95 force 120. I've been reading through all these forms trying to find a solution to my problem and haven't found it yet.
It will start right up and will run for 10 seconds and then die. It was running great last season until towards the end of the season right before I pulled out of the water and it was doing the same thing so I figured it might need a tuneup. That being said I winterized it and last month started working on it, I rebuilt the carbs changed out all the fuel line and filters new spark plugs, new wires compression test was beautiful. I'm very familiar with mechanics and have rebuilt big and small motors including outboards but I'm unfamiliar with the force 120.
After all my research I finally thought I found the solution and thought it was the "fuel enrichment solenoid" so I put a line clamp on that fuel line and whoa be hold it ran beautifully for 15 minutes. And I thought it was golden.
So I ordered a new one and installed it and put the boat in the water today and I'm having the exact same situation. But this time trying to cramp line or even disconnect it is not working at all. I need your help please
