1985 Johnson 20 HP carb/throttle issue
travisj2001
I just purchased a 1985 Johnson 20 HP J20CRCLOS and it runs great but seems under powered. I noticed at WOT the butterfly in the carb only open about 20%. It's my understanding that it should open 99.9%. If that is the case, should it be adjusted on the throttle rod screw towards the back of the motor or the actual carb itself?
Also, if I make this adjustment, will I have to re-adjust the air/fuel mixture screw?
Any help is appreciated. Thanks!
flyingscott
The throttle should be adjusted at the carb. There should be a roller on the carb that needs to be synced with the cam on the magneto. Find the line on the cam and that is where you want the carb to start opening. Sometimes the roller and or the cam is broke. look at those first. Do not adjust the screw at the back of the flywheel as I believe that is a timing screw. No you shouldl not need to readjust the fuel mix screw. That butterfly should open to a 90 deg angle.
That throttle rod screw is often adjusted because when it is correct it " looks wrong "------There should be about 3/16" clearance there at idle.
interalian
and make sure you're testing throttle plate action while the gearcase is in forward gear first, not neutral
travisj2001
Everything checked out with the collar on the throttle rod and the cam and magneto lined up perfectly as well. As I was checking I did realize that I thought it wasn't fully opening due to being in neutral. After popping into gear it did exactly what it was supposed to. So I have no issues, just an motor head with little outboard experience. Thanks everyone.
cowboy18
hey travis can you tell me the measurement from end of throttle rod to lock nut please having similar issue
