Re: Mercruise 120/140 hp cyl. head interchange
I don't know if they will swap on not but as a general guide to what is and is not interchangeable you can simply compare the gaskets, in this case the head and manifold gaskets, if they don't match up than you can stop there! If they do than look a little deeper such as chamber volume, valve actuation, external plumbing etc. <br />Good luck.
