PatinIdaho
- Oct 7, 2014
- 486
Called a Screw rod. I have had them stuck before and what i did to get it loose was i secure the housing and use a propane torch with MAP gas to heat the housing HOT! Use a board to protect the rod and hit it with a hammer. First one way then the other. If it comes out great if not soak it with some penetrating oil for a while and try again.
Sooner or later it will come out.
