1980 johnson 4.5 not running full throttle
rodknee1231
Just rebuild carb yesterday revved up really good. Gave it back to the guy and he called and said it didnt wanna go past half throttle. Where to start besides the main jet cleaning possibly lean rich out of adjustment.? I said mess with the choke to see it runs better with choke
oldboat1
Did the work using your shop tank? Maybe he's running with bad gas, maybe water.
rodknee1231
Yes it did started first pull too. I guess I'll be cleaning the main jet again to see if that's the problem. What else would cause that. He said it runs better with half choke but not like it's supposed to. Wondering if the bowl is filling as it should
ondarvr
There is typically a vent on the gas cap that needs to be opened.
rodknee1231
He says he opened it. I'm guessing a main jet has some crud in it. Just sucks cuz it hard to get all the way up in that pickup tube
Most folks pick on the carburetor first when trouble shooting.--Have you checked compression ?-Have you checked for strong spark on both leads ?
rodknee1231
Yea well when I got the carb was horrible full of gunk
Crosbyman
if you unscrew the cap's vent screw you still have holes under the seal (on older JW anyway...) that sometimes get all crudded up closed. you need to open up these air holes with a piece of wire (paperclip will do) you must see light .
in the mean time run the motor with the fuel cap removed...completely...
if it runs fine.... then the small air holes need to be cleaned out !!
the thank has an external round filter which needs to be clear also... was it replaced ??
oldboat1
Have the urge to circle back to the customer's fuel supply. (Runs fine on your supply, maybe not so well on his?) I've had that issue before, resulting in a double carb cleaning. I was the customer!
If the carb was mucked up before, bad fuel is coming from somewhere (or was). Probably should also make sure he's using a 50:1 mix.
