Installing Lower Shift Cable Jacket Thru The Shift Cable Bellows - Any Tips?
San_Diego_SeaRay
Alpha One Gen One transom assembly
Trying to feed the shift cable jacket into thru the shift cable bellows moving from Aft to Forward. My lord, is there any part of rebuilding a transom that's easy? Other than applying motor oil or grease to the fat bronze leading end of the jacket, does anyone have any tips? I can't be the only person struggling with this. :)
FreeBeeTony
I couldn't do it with the bellows attached to the transom,
Had to have it in my hand......still was a PITA!.
Rick Stephens
I'd sprayed a touch of Slick50 spray lube on the outside of the housing and it slid right on. Use a rag damp with lacquer thinner to wipe up and was a very simple process.
