Shift rod adjustment
Ramsey1463
Hey guys. New to the forum and I would appreciate any help. I have a 1974 evinrude model 50473m. I changed the water pump and the shift rod accidentally got turned in the process. I put the lower unit back on but now the motor won't go into forward. I can put it in reverse but the throttle stops when I try forward. My question is how do I adjust the rod to make sure it goes in gear? Thanks in advance for any help.
Ramsey1463
Thank you so much. I appreciate the welcome. I'll work on it when I get home tonight and post the results. Thanks again.
Ramsey1463
Update. I adjusted the shift rod height and thought I should try to shift the motor before I put the lower unit back on. I still can't get the throttle to kick into forward. I even took the shift rod link off to see if it was stuck on something. Then I took the throttle apart to make sure nothing was broke. Everything appears ok. Any advice on troubleshooting on this?
Watermann
Did you remove the shift and throttle cables from motor end and try to run the controls forwards and backwards?
Ramsey1463
I just did and same thing. It goes in reverse and neutral just fine but won't go forward. Is it an issue with the control box?
I believe that lower unit has an oil pump to provide pressure to make the shifting easier.---Motor may shift easier when it is running.
Watermann
Or a cable, disconnect the cables from both ends, the cable should pull and push back and forth easily with your fingers and then your control is free and should move easily as well.
Ramsey1463
No Title
I feel stupid even asking but how do I disconnect the cable from this end? I'm sure it's simple but I've never dealt with a control box before.
Watermann
There's a set screw on the top of the plastic end pieces that bites down on the cable core, back it off until they're free but don't loose it by taking it all the way out.
flyingscott
Did you try turning the propeller by hand while shifting. Could be the shifting dog is hitting the gear out of alignment. Don't have the engine running while doing this
Ramsey1463
I got one free but of course the other is stripped. I'm going to do the smart thing and call it a night before I get frustrated and break something trying to force it out. I'll work on it some more tomorrow and update. I really do appreciate all your help.
Ramsey1463
Flyingscott I still have the lower unit off. I figured if there was a problem it would be easier to pinpoint where exactly it was.
flyingscott
Try turning the propshaft and turn the driveshaft while you are shifting may need some help for that.
Watermann
Your luck is the same as mine.. been through all sorts of trails since I started working on old boats. Hey I know, maybe you should spin the prop on the removed LU, maybe that would make you feel better :lol:
oldboat1
just a thought -- while the l.u. is still off you might put it in a tub of water and spin the driveshaft clockwise with a hand drill, then manually shift. With oil in the crankcase, the assist system should work too -- and also a chance to test the new water pump operation. In any case you should be able to shift normally. (Keep the rotation speed low while shifting -- duplicating idle speed shift range.)
Ramsey1463
So I finally got the set screws out. The first cable I can move by hand but the back one won't bulge. The throttle still won't go into forward either. I'm guessing this is because of the cable not bulging? Do I just need a new cable or is there something else I can try?
Watermann
So with both cables disconnected at each end will the control lever manipulate freely now? If you have one cable that won't budge then yeah it's bad and I would replace both of them while you have it all apart, the other won't be very far behind it.
Before removing the old cables, tie and duct tape a piece of small rope to the end of an old one so you have a way to drag the new ones back through. Once out you can lay the old cables flat and get a good measurement for the replacement ones. Be sure to order the correct replacement cables too, there's old and new style OMC cables.
