1999 Johnson 150 Upper Driveshaft Seals
golson
Help me out please. I got my lower unit out and when I took the bearing housing out I saw no seals from parts "7A and "7B" from the attachment when I removed the housing. I have the correct manual and model number of my outboard but the parts are not matching. I got spare parts but when I went to install the two seals as the picture has, the impeller housing plate will not sit flush. I am thinking to not use these seals but then how does the water stay out and oil stay in? From the seal in the bearing housing?
If those seals were missing the lower unit would fill with water and come to a dynamic halt.---Any pictures of the housing ?------Were you using this lower unit ?
golson
The housing is item 6 in picture. What was missing or not present was 7A and 7B....
golson
Not in the housing ?
yea there is a single large seal in housing. but what i did was use the two that the diagram shows. maybe someone did a shortcut before. on another note. which direction does the housing go? there is a oil hole on bottom side and i think it goes pointed forward or aft.
golson
well if it was it is black now. here is a picture of what was in there.
???---They have switched to a one piece double lip seal.---But I like the 2 seal set-up and think it is much better !!
