4hp 1974 4336 Evindure Fleetwin No High Power performance
Wojo61
I have an old 4hp 2 stroke.
Carburetor was just rebuild - , Adjusted low speed 1.5 turns out, High Speed .75 turns out. Engine starts
Engine starts and runs at low speed , When I go to full throttle engine does not achieve full power , new Plugs: Good spark.- - new fuel, points: gap cleaned and set.
I am suspecting a fuel pump issue. How do I check it? Any thoughts on fuel pump or other areas to investigate.
Any thoughts
Does spark jump a gap of 1/4" or more, yes or no ?---------Those needle setting are for the motor to start and keep running.-------You MUST adjust them on a boat after motor is warmed up.-----------You check the fuel pump by operating the manual pump, does it run better when you do that ?---------Have you checked compression ?--------To me it sounds like it may be running on one cylinder.
lindy46
Have you adjusted the high speed needle at full throttle on the water? Is your tank vent open? Does it run at high speed if you squeeze the fuel bulb? How's compression?
Wojo61
#2 Today, 03:43 PM
Does spark jump a gap of 1/4" or more, yes or no ? : I don't know what you mean, If I take the spark plug out and pull the cord the spark jumps the gap on the plug.
Those needle setting are for the motor to start and keep running.-------You MUST adjust them on a boat after motor is warmed up : I did adjust after it was warmed up at both low and high power : in a drum..-----------
You check the fuel pump by operating the manual pump, does it run better when you do that ? I guess again I don't know what you mean-by the manual pump.
-Have you checked compression ?--------To me it sounds like it may be running on one cylinder: Did not but will tomorrow.
Have you adjusted the high speed needle at full throttle on the water? --No on the water, but since its only 4hp I did try full throttle in a 75 gallon drum,
Is your tank vent open? Yes external tank vent is open
Does it run at high speed if you squeeze the fuel bulb? I will try this . If it speeds up does that imply a new fuel pump is required
Jumping the wee gap on the plug is an " indication " of spark , but not a good test.----Will spark jump a gap of 1/4" or more with a snap you can hear ?---Yes or no ?----And the manual pump is the bulb on the hose !
Wojo61
Thanks for the clarification . I ll check in AM . If I have a strong spark. and the manual pump increases power I assume its the fuel pump.
If spark is weak ? I had to the points and condenser?
flyingscott
Take it out on the lake and adjust it. It harder for the motor to achieve full RPMs in the drum.
oldboat1
Was high(er) end operation the original problem, or did that come up more recently? Was it a problem before the carb rebuild?
Wojo61
Had high power end of last season during operational use. This was prior to carb rebuild
Remove plug wires one at a time .-----Will motor start and run on one of the cylinders ?
lindy46
You really need to get out on the lake to test properly. You can only do so much in a test tank.
tomhath
Master Chief Petty Officer
Pay close attention to this advice. The motor will start and run fine on one cylinder, a two-stroke will sound okay unless you are quite familiar with them.
oldboat1
With a little one, should be able to test spark (adjustable spark tester) and do drop test before hitting the lake, along with getting the carb settings close to correct. If running on both with strong spark, I would try leaning out the h.s. needle slightly (clockwise) at 3/4 throttle or so, and look for an increase in rpms -- find best lean/rich setting -- then go back and readjust the idle needle adjustment. Should be able to idle smoothly, and advance throttle without stumbling -- smooth operation on both ends. Then finish up in the lake. IMO, before hitting the lake you should know whether h.s. operation is likely to be a problem.
As the higher speed operation became an issue after the carb rebuild, sounds like a carb issue of some kind at the moment. (Right now, might be able to advertise it on CL as "ran well the last time it was used". Yet another option....:rolleyes:)
Wojo61
Thanks for all the comments.
I just completed another tank test based upon comments above .
1) No difference in high speed when pumping the manual bulb
2) Pulled Spark plugs and pulled starter cord. : Upper cylinder spark did jump 1/4 , Lower cylinder spark did not jump, but it did jump across the plug.
When started and running , Pulled upper plug, engine died
When Started and running , Pulled lower plug no perceived difference in engine operations
lindy46
So it sounds like it's running on the upper cylinder only. Time to pull the flywheel again and check points and coils. You say new points - did you clean them thoroughly? Even new points can have a coating that will keep them from firing properly. Use acetone on a strip of business card stock to clean them. Then make sure they're gapped to 0.020". Your lower coil also may be weak and need replacing.
oldboat1
^^^Agree. Points and/or lower coil. Need to get the ignition issue resolved before proceeding. Don't mean to flog dead horses, but you really need a $10 adjustable spark tester to know what you have.
It sometimes takes a LOT of convincing to get folks to believe that weak spark can jump a gap on a sparkplug in open air.----That same sparkplug in the cylinder with air compressed to say 80 PSI needs a lot more voltage to get a spark .------The ignition system was designed / built to be able to produce up to 28000 volts.------A good magneto will fire across a gap of 5/16" with a " snap , crackle , pop " you can hear.-----Then you can say " I have good spark "
Wojo61
On a spark tester, what is the measurement criteria used, I assume a basic OHM/Volt meter can not be applied is this situation.
Are these available at the local auto parts store.?
What the test criteria for the coil
