Johnson 15hp top speed adjustment
Dj00140
So I bought a small 14' Lund v with a 79 johnson 15hp short shaft, when I bought it the motor would not start easily or idle well but it would run at 17-18mph. I brought it in and they cleaned the carb and now it starts perfect one pull idles great but it now has a top speed of 13 mph, any suggestions?
Dj00140
Yes thats a good idea but it is a 50 minute drive and the work was done last fall so I thought there might be a trick I could try like adjusting the carb before I went any further.
Vic.S
I think you will find that there is only a slow running mixture adjustment but you might check that when the throttle is opened fully that the cab butterfly valve does go to the fully open position
Dj00140
I will take airbox off tomorrow and check this, if that is ok could I try pouring fuel into air intake at full throttle to see if it is a fuel delivery issue? I am open to other suggestions.
David Young
Yep. Like Vic.S, i would check to make sure you are getting full throttle.
Dj00140
I can move the piece on the carb that rotates the butterfly about 1/8"-1/4" further than how far the throttle at top speed would open it, so the carb looks like it pretty much is opening entirely.
David Young
4 or 5 mph loss is quiet a bit. I would at least call the people who worked on it, maybe they can tell you what they did for you to lose so much speed.
