1973 50hp Evinrude no spark
couch702
Ok guys im back. Went to go fishing this morning, and when launching my boat it would not start. Long story short i pulled the plugs attched to the coil, and the plugs were not firing. Niether one fired. The boat ran great last time i was out, so what is causing this?
boobie
Disconnect the black/yellow wire from the pulse pack and see what happens.
oldboat1
Think I would revisit earlier fixes, particularly the wiring fix.
Additionally, the flywheel may not have been torqued down properly at some point, and has changed position on the shaft (throws off timing). The key may have been fully or partially sheared as an effect. If fully sheared and the flywheel is loose on the shaft, it might be spinning freely without turning the engine (i.e., no spark generated). Try to turn the flywheel clockwise by hand, and see if the engine turns with it.
oldboat1
Not the key per se -- position of the flywheel on the shaft. No spark if timing is off far enough.
There are other ways of checking timing, but think I would suggest pulling the flywheel and having a look. Also look for frayed wires, leaking around the stator -- any clues, then do that testing (cdielectronics is a good source, as indicated).
flyingscott
As long as the flywheel is turning you should have spark just because the key is sheared means nothing. If that was true you could not have a backfire which is usually what happens with a sheared key. The key keeps the pistons in time not the spark.
flyingscott
Post# 8 you said that the key being being sheared means no spark. That post proves my point just because the key is sheared does not mean there is no spark in the post you quote he is backfiring, That means with a sheared key there is still spark. The OP has an absence of spark a flywheel key will not cause an absence of spark . As long as the flywheel is turning the magnets are still going around the stator producing spark. I am not going down this rabbit hole his flywheel key is not the problem as he has no spark.
oldboat1
Watch out for those rabbit holes, F.S.
Agreed----When the key is sheared there will still be spark if all the ignition components are in good shape.----With a sheared key the spark will be at the wrong time !!!
oldboat1
Seems right.
Couch, wasn't sure in your earlier posts whether you were checking for spark with a tester -- recommend that, just to be sure. You may have weak spark, maybe spark on one cylinder -- would want to be sure for troubleshooting. In addition, that rewiring of the plug -- seems that's worth revisiting. I don't think you had pulled the flywheel, so may be up to that for a look, but would want to check the prior work first.
couch702
I found the timing block / sensor coil is bad. Its grounding out somewhere. So i have the part on order. And when i gwt it swapped out it hopfully is fixed.
couch702
Changed out the ignition coil and that thing fires up on the first turn of the key. 😄 Another problem solved. I hope i dont havr another for a while.
