Limber holes1900 Stratos
1900clueless
Trying to find out where and how, to find and clear, limber holes in 1996 1900 Stratos, with center console.??
jbcurt00
If present, they are all below deck and not likely you'll be able to find or clear them w out pulling the deck(floor)
Why do you think you need too?
1900clueless
Cut a 6" hole in deck and foam, Foam is saturated with water is 8" DEEP and have been dumping water for 2 days, (on trailer) takes about an hour to fill up.
jbcurt00
Clearing your limber holes isnt likely to solve that. And now that its waterlogged, the foam is no longer doing what its supposed to.
mr 88
Agree ^ the foam will never dry out and add a ton of weight to the boat. Deck has to come off , foam replaced and source of leak found. You may just fill her up with water and see where its coming from. Sometimes that method will work . It may be a crack that leaks with pressure so it might not show up while its sitting on a trailer.I would be surprised if it even has limber holes, not that it matters at this point. I had a aluminum boat that leaked slowly,filled it up on the trailer and it never leaked using that method, needed outside water pressure.
1900clueless
Its draining, just slow. I was hopping to find the limber holes so it can drain as designed instead of dipping.
jbcurt00
It may drain some water, but its not likely to ever dry out...
mr 88
The water is slowly dripping out of the saturated foam, has nothing to do with limber holes. Never will dry out ,should be removed and replaced.
