So my 98 Johnson 90 hp V4 seems to be running on 3 cylinders. (Although boat runs great I still feel as it is misfiring and vibrates on idle) I have good spark, good compression...On initial test, cylinder did not go down when I removed the spark wire for the cylinder in question. A friend who knows his motors checked my fuel and said it smelled funky and old and that this can cause a cylinder to not work? He suggested I pump fuel out and try again with fresh fuel. If this still does not get cylinder going that I should rebuild carb. So here are my questions...
Would bad fuel make just 1 cylinder quit?
If I have to change carb, would just rebuilding one in question do or should I do all 4?
