82 Johnson 35hp electric start?
drewshep
Hi, i really want to put an electric start on my 35hp Johnson, it is too hard to pull start. I've seen it done with other Johnson and evinrudes but i cant tell if i can get one to fit, can anyone link one thats fits and or what do i need. thx
There are many years of motors that have the parts and pieces that will fit yours.-----20 / 25 / 30 ./ 35 hp models from 1980 to 1995 would fit.
drewshep
I saw i lot of people take Evinrude parts, i cant seem to find any johnson electric start parts.
?????--But only the paint colour would be different !
oldboat1
You need a J. or E. parts motor. I would look for an electric starting model close to yours in vintage and hp, and go from there. Having a suitable sister motor has additional advantages. It gives you a template for working on yours, along with a load of parts you may need later for other fixes.
oldboat1
But an '80 25 hp starter would fit, for example. That's going by part numbers. You would still need the correct bracket (probably the '80, but would need to check). Need to check parts diagrams as you go, but piece by piece assembly is very difficult -- particularly if you haven't done it before. What about the electricals? Where do you figure to mount a solenoid?
drewshep
Going off pictures I have found it would go next to the starter if you can see it there https://www.google.com/imgres?imgur...d=0ahUKEwjNxOaDkrDLAhXGrB4KHeRkC4oQMwgdKAAwAA
????---A 40 hp was not on the list of donor motors, Evinrude or Johson are both the same save for the color of the paint !
