Running without lower unit ? 73 Johnson 135
rodknee1231
Can I run my motor without the lower unit? The water pump is trashed and I don't have the cash.to replace it right now but I just rebuilt the powerhead so I wanna run it to time it so I'm sure I'll require some water. Can I hook a hose to one of the tubes ?
F_R
Seems like it would be possible. Connect the hose to the "UP" tube. But you are supposed to run it in gear at full throttle to set the timing. How do you propose to do that? Yeah, I know some guys have their secret method. I have mine.
rodknee1231
Well then spill the beans man lol.
boobie
Look in the Top Secret Files for the Joe Reeves method of setting the WOT timing at cranking speed. Works real good. And seeing you don't have the lower unit on you don't even have to have it running, just cranking over.
rodknee1231
I read that too. Figured that's what you would say. Btw can I leave the plugs in and crank it or do I need to keep fuel connected and pull the plugs and ground them somehow. How would I ground the coils ?
Wait until you have repaired the waterpump. You will want the motor to break-in at proper water temp and water pressure. Make sure she is well-oiled until then,
boobie
Look up the procedure as it will tell you exactly what to do.
