1973 135hp Johnson choke different than my 76 85hp
rodknee1231
So I I have a 85 hp with a blown up power head. I'm putting my 135 power head in it and I noticed the 135 powerhead has a sensor in the top of the block the 85 doesn't and the 135 also has a 2 wire choke solenoid while the one on the 85 is just 1 fireman some one clear this up for me as the service manual I have is for my 85
The 73 has what is called " thermo electric choke "---designed to help newbies start motors.------As follows.-----On a cold motor when key is turned to " on " the choke comes on partially.---Operator operates choke switch for full choke.----When motor starts the choke stays partially on untill thermo switch opens.------This feature was usually bypassed.-----Computers do all the thinking today so folks just need to push a button to start thier machines.------The 2 wire solenoid can be used on the 76 model.
rodknee1231
So it will always need opened manually but the thermo switch will close it
F_R
Here's the deal: The 1973 motors had the duel stage choke as described, along with the sensor. Later on, it was changed to a single stage choke, which only closed when the driver activates the switch. HOWEVER, there was a service bulletin advising converting the dual stage choke to the single stage. All that is required is connecting BOTH choke solenoid wires to the blue/white wire coming from the choke switch. Sensor is no longer used nor needed.
F_R
No Title
Like this:
rodknee1231
Could I possibly use that thermo switch for a led overheat light ?
??????----NO that thermo switch opens up once the motor has reached a certain temperature._____And both motors in question have an overheat swtch and buzzer in the control box to SOUND an overheat alarm.---Hot lights are not the best thing on a boat !
rodknee1231
Well it can never hurt to have more than 1 warning that's why I ask
F_R
Your proposed light would be on when cold and go off when it reaches something near normal temp. Unless you get complicated with a relay. Even then it switches at below normal operating temp. Not what you are looking for.
rodknee1231
Gotcha thanks guys
