1999 Johnson 175 Troubleshooting - Just can't pinpoint the problem
LakeConroebassmaster
How it started: The Johnson was running fine, better than usual actually since I recently replaced the spark plugs (which seemed to resolve all my cold starting issues). Then last week I ran across the lake to fish. Cranked great, ran strong and true. Heading back from our last spot and the engine bogged down and died. Its done that before. Usually it just cranks right back up, especially if the engine is warm. This time it didn't.It just lightly smokes, and turns over and over and over.
So I went through the basics first,
1) make sure its in neutral
2) kill switch is in correct position
3) bulb is pumped
4) Use choke to start
I took out the spark plugs, cleaned them, put them back in, nothing. Checked the gas for water, looks clean. Checked the spark plugs, I have spark. I disconnected the kill switch from the ignition and tried to crank it, still nothing. I sprayed starter fluid, no reaction of any kind. Checked the fuel filter piece, and let out some gas so Im assuming its getting fuel. The battery is fully charged, with plenty of cold cranking amps, bought within the last year. I definitely have plenty of gas and oil. Hopefully you guys can point me in the right direction
reiddo1
Why not try disconnecting the wiring harness at the engine and jump starting it. If she fires up, you know it is then either a wiring harness or starter switch issue. Be prepared to pull spark plug wires with well insulated pliers to shut it down if it starts though. Mine continued to run until I had pulled 4 wires.
Faztbullet
retest spark as it should jump a 1/4 gap with a pop/snap. If spark is weak it will not fire under compression.
Ok, I retested the spark plugs. I recorded the results so you could take a look at them. Two tests, and I recorded the motor turning over so you could get a better idea of what it sounds/looks like. The only way I could figure out to get the best video quality was to upload it to youtube so here are the links. They are all less than 30 seconds and provide valuable info. Spark seems to be pretty weak.
Test 1
https://youtu.be/Iekwr6T4ipc
Test 2
https://youtu.be/Swcd1yODYUk
Motor turning over
https://youtu.be/s51TCKq0L20
bob johnson
Test 1
Test 2
Motor turning over
well several things.......when you crank your motor over to even TRY to start it....you should have it in water or on muffs running water!!!!!!!!!!!!!!!
next...you need to KEEP the spark plug GROUNDED to get any spark.... you were hanging in air....there was little chance to check that plug with you dynamicly holding the plug in space out away from that bolt head!!!
to make life easy...get a simple spark plug tester at the auto parts store.....it fixed solidly to both the plug and the spark plug wire.... and you can watch the spark jump the gap.....which is adjustable.... set it for 7/16th " at first........
doesn't sound like the engine is cranking fast enough.... but that is subjective.... you did get a spark once in a while.... I bet your RPMS during cranking are right at the minimum to make spark
bob
Ok, Im an idiot Bob. Thats what I get for being in a hurry. You were right to call me out on that, and I should be more conscious of what I am doing. Thats definitely a first. Maybe I misunderstood faztbullet when he said that it should jump a 1/4" gap with a pop/snap. Here is test #3 with the motor in the water and the spark plug grounded.
https://youtu.be/C7Njcmk76E0
bob johnson
Ok, Im an idiot Bob. Thats what I get for being in a hurry. Maybe I misunderstood faztbullet when he said that it should jump a 1/4" gap with a pop/snap. That is the first time I have ever tried to start it without running water.
this is a sample spark tester...it clips to the top of the plug and the one end goes into the spark plug boot.... and you can see how far the spark will jump across air...in the black compartment.... this one has measurements printed on it..... very simple very easy and cheap
bob
Often mis-understood.------Good spark jumps a gap of 7/16" or more on a test gadget.-----Sparkplugs are not used in that testing !
Ok so I went to O'Reilly to pick up this spark plug gadget but they had never seen it before, including the manager, and had nothing comparable. So on the way back home I called my father who originally installed the new spark plugs(To try to figure out where to pick one up), and he said he has the gap testing tool, and he set the gap measurements when he installed the spark plugs. (About 1-2 hours on the motor prior to now.)
Again you appear to mis-understand.---This is not about adjusting the gap on a sparkplug.--This is about testing the maximum voltage that your ignition system can produce.--You could even make something up with 2 pieces of wire glued on a piece of cardboard .--Just have a 7/16" gap between the wires !
oldboat1
Google spark testers to see what they look like (some variety). Want to say any auto parts store --- but apparently not that particular O'Reillys! (maybe they misunderstood -- doesn't have to look like the one pictured).
on contaminated gas -- would want to take a sample, preferably from the bottom of the tank. Let it set in a glass jar overnight, and look for separation.
The cranking sounds a little slow to me as well. Cranking out of water can destroy an impeller, although less likely if it didn't fire up dry. Check pumping and temp when she runs.
Ahhhhh ok ok ok. Thank You Racerone for explaining that one out to me. I understand now. Let me figure out where I am going to get this gadget or if I can rig up something myself and I will get back to you guys.
Ok so I went cruising to a couple different stores and found the gadget. $9.00 at O'Reilly across town. Came home and hooked it up. Lowered the boat into the water, and cranked it (started with a small gap just as a baseline) nothing. No spark at all. Im talking a 1/8". I had it grounded to the same bolt I was using on the spark plug earlier. Am I doing something wrong? Here is a picture of the spark tester and the distance I tried.
oldboat1
That tester will work (watch out for the clamp breaking -- need to use it a little gently). But do make sure it's grounded well.
You should have about 1/2 inch with that motor, and when firing well will give you more than that.
Based on your pics, I would expect to see a bit of spark anyway. Wire connection inside boot can be an issue -- want to look for simple stuff first. And I would be absolutely sure the tester is grounded -- maybe try a different ground, paint can be an issue.
Ok, I'll work on the pointers you gave me and get back to you.. It will be a few hours but I'll retest as soon as I can and post a video if possible. Thanks for the direction oldboat.
bob johnson
do not hook the tester to a bolt.... the tester should just CLAMP onto the end of the spark plus( that is screwed into the head!!!) and the other stud goes into the spark plug wire boot!!!! just like the spark plug original does..... if you have the gap set at about 1/4" and spark does not jump across the gap you SET....then you have an electrical issue......
oldboat1
well, the tester replaces the plug to test effectiveness of the CD or magneto system -- clip connects to the block somewhere for ground, and the other end is inserted into the plug boot. The tester does produce an open spark (hopefully), so want to keep it away from an open plug hole or anything combustible.
Difficulty is that the clip (a) is fragile, and (b) needs a solid block ground -- and (c) the clip on some of them is too small to easily fit over some bolt heads. And (d), you are limited for a ground location by the length of the plug wire. Oh, and -- (e) -- you have to hook up the tester somewhere visible to you while cranking.
But they work....
You still may have a bad plug (tester doesn't test the plug itself), so once you determine the magneto or CD system is operating, it's a good idea to put in new plugs, properly gapped. At least clean and gap the old ones.
If you don't get spark with the tester, look for simple reasons first -- that ground connection at the block, or the spring connector up in the plug boot.
I tested a couple different connections. so plug wire ------>tester--------->clipped to spark plug that was still grounded in the block. I tried this multiple times with multiple different gaps, small gaps and large gaps. (On two different sides of the motor, two different plugs) I even tried with it on the bolt again. I was unable to produce any spark. No spark at all. What should be my next step for troubleshooting the electrical issue I am apparently having?
oldboat1
If you managed to get the tester clip around the base of an installed plug, you would have a ground, but there is no reason to do that. For a tester ground to the engine block, you would clamp to a convenient bolt head or similar, scraping off some paint if you need to in order to get continuity.
If you are ready to check the CD ignition, a good source is http://www.ebasicpower.com/downloads...ting_Guide.pdf .
