gm280
Thread starter- Joined
- Jun 26, 2011
- 14,605
Okay, I will confess up front. I am in no way any computer expert and I didn't stay in a Holiday Inn last night either. But I do have a few questions before buying a new laptop. First off, how can you tell if your computer is the problem, or the router/modem (one unit), or actual cable link? Here is what I have done thus far. I have done a few speed tests with the usual speed test links and one will state that I have great connections with medium upload and download speeds (20-30mbps most of the time, but not always). The other states I have sorry connections (5-8mbps) not even close to what I am paying for from the cable link. So how do I actually tell which is correct?
Here is my usual problem. When I log on each morning, I usually scan the local news groups and then end up here on iboats. This can take anywhere from a few minutes to an hour. And with certain links, as soon as I link up, the site responds with "link stopped working" messages. And I can't get anything to work other then closing the computer out of that dead non-working site and reinitiating again. The back arrow doesn't work and neither does the refresh key. Then some other sites are sort of okay, but slow and nothing to write home about. And then others seem fairly responsive. And some times I can minimize the screen and maximize it again and it starts working for a while. So again, how do I tell if it is my laptop, the site, the router/modem, the cable company, or what? Some days ever place I link to stops work on me nearly instantly.
My present laptop is about four years old and obviously not a modern high speed setup. But this is getting really old. It originally didn't do such things, but then the cable company may not have had as many customers sharing the cable links either. So I am wondering, do I need to buy new, or what? :help:
I can try things if anybody has any suggestions. But mind you I am certainly not computer savvy either. So any ideas have to be spelled out really simple.
I did take the computer apart and clean everything. There was a lot of dust in the CPU radiator section where the fan cools things and I cleaned all that out. I also clean the CPU heat-sink area and applied new fresh Artic Grease back (thermal grease compound) on the CPU heat-sink again. No change.
Any ideas? :noidea:
And one last thing. This is a Dell INSPIRON N5010 laptop with 300GB hard drive and 6GB RAM 2.4GB i3 CPU Core, running Windows 7 SP-1 with 64-bit operating system.
Any ideas? :noidea:
