acts like a slipping clutch
montara24d
Have a 1977 25hp Johnson mod#25E77S. While running slow if I crack the gas wide open the motor revs, & it don't go. My first thought was broken shear pin, pulled the prop, & all is good. If I give it the gas slow & steady, all is good, boat gets up on plane with no problem. If I give it the gas all at once it acts just like a car with a stick shift & a slipping clutch. Thoughts?
Thanks, John
sutor623
Are you already in gear when you lay down on the throttle, or are you just slapping it in gear and rolling out? I would think spun prop hub, but you said shear pin, so there is no hub on this prop?
Any other signs of clutch dog wear? Metal in the gear oil, popping out of gear on its own, hard shifting into F-N or R?
flyingscott
That prop has a hub on it even with a drive pin there is a rubber hub. Since you don't say it is banging I will go with a spun hub. scratch a line across the inside of the prop take it for a run till it does it. When it does it take the prop off and see if everything is lined up
Drive pin is the proper term on that motor.-------Even with a pin most props still have a rubber drive hub.
montara24d
Happens when I'm running along slow in gear & then give it the throttle all at once. I will remove the prop & scratch a mark, to check for a spun prop, thanks for the suggestion. Gear oil looks good. No strange noise like banging or gear noise. I have owned the motor for five years, we are discussing a 1977 motor, & it could very well be the original prop.
John
ondarvr
Is this a new issue, or has it been doing it for a long time?
sutor623
John
Cool man, it certainly doesnt sound like a gearcase issue. I think you got lucky and its the prop hub. Let us know how the slip test goes.
montara24d
Thanks to all who responded with help, I now know that I have a spun Prop.
Thanks again, John
glust
If it a clutch dog you will know it. When it slips you get a real loud bang like one of your kids is in the back of the boat with a 5 lb sledge hammer whacking away at your floor
glust
that rubber hub in the prop is like a weak link safety valve. I'd much rather replace a spun prop than hit something in the water and have it tear out a gear or even worse, break a crank or bend the driveshaft. Think what happens when you hit something with the push mower...
Bman2895
Ive has something similar to this happen to me on a 20hp. I got some weeds on the prop and it wouldnt revup and stay in gear. pulled the motor up and cleared it all off and it was fine
