Goodday,
( Longtime member but first post now ), Restoring a 1985 Fletcher Arrowbolt 21 a the moment, got everything almost out, some deck was in a bad shape.
However the stringers and the stern are in a good shape. ( will post some pics later )
Engine is a 5.7 mercruiser with some rust on the outside, but engine runs fine, have some small problems but easy to solve.
As the boat was always running in raw seawater the risers and part of the exhaust was eated by the seawater.
So i was thinking about changing the whole cooling system with a closed coolingsystem, but not with a tradicional heat exchanger, ( as it will take some time to fabricate also)
But with a aircooled radiator or radiators with some electric fans running on it.
Also leaving the engine "room" open on the top. as the exhaust wont be cooled by water also, more or less as you see on some jetboats..
I have some ideas where to put the radiator or radiators,
Reading around the net but not much info found, so asking here, any ideas, and pros and cons about this idea..
Tnx
Tnx
