quirky 1998 200 hp johnson outboard
bgbsshntr
Well, I guess even though I paid someone to swap the power head, and go through the carbs, I am going to tear into those at my friend's house. He has a Sonic cleaner, so by doing this I will eliminate this as an issue
bgbsshntr
Did you read the whole post? It detonated #3 cylinder and blew a big hole in it. Power head was swapped because of that. I have been a customer in my club tournament ever since
bgbsshntr
I am headed to my friends this morning, but something I noticed yesterday reinstalling the flywheel. The key on one side seems pretty flush, and the other side you can click with a finger nail. Before we tear into the carbs I am going to Mark the shaft dead center and see if the flywheel is slipping slightly at start up.
daselbee
Read the whole thing from the start as it progressed, but forgot the first part of the thread as it did progress.
Sorry.
bgbsshntr
Put a new key in from the hardware store, the missing stopped and ran great on the hose. Took it to the boat ramp and blah, ran just like it did yesterday. I planned on ordering a key from here. I will pull the flywheel again because I think the high pressure in our motors probably sheered the the cheap hardware store one. 50 cents at the hardware, like twelve dollars from boat supplies. I am learning slowly.
bgbsshntr
I don't get it, I was really hoping the keyway let go. Ran perfect on the hose, dunk it at the ramp and runs like ****. We even warmed up my friends motor and checked the on hose rpms and timing then set mine to the same. I understand it being different on the hose, but I don't understand the missing when dunked. Any ideas would be awesome.
bgbsshntr
UPDATE...... I finally got her on plane. After replacing the stator and all the other stuff I did, which needed done, found out that one plug carbon fouling and stalling when at the ramp was the coil wires on the two left side cylinders we're reversed. The wire lengths are confusing on that side and really didn't see the colored strips until looking at real good. Lucky for me my friend hooked his up wrong when he put the power pack back on after we tried on my motor. His was doing exactly the same thing as mine. I just have one more question and I will leave you all alone. Because of breaking in the mechanic actually put way too much oil in the gas, it looked like Smurf pee. Can that clog the fuel water separator filter I installed. I have since drained and thinned the mixture down. You all are so full of information, thank you so much.
daselbee
You know, this is quite interesting. I have seen this mis-plugging of primary wires all too often.
BUT!!! The symptoms you described are NOT what I observe when an engine comes to me with the #2 and #4 primary wires swapped.
The symptoms in every case have been that the engine barely runs, runs very very poorly, will not stay running, and here is the kicker....
when it finally stalls out, it does so with a kick that makes the flywheel spin backwards for a quarter of a revolution.
You never mentioned any of these symptoms....did you experience such?
And NO, the extra oil in the gas will not plug up your filters.
bgbsshntr
After the components were replaced and the wires were crossed, it actually ran good on the hose but like a big crap bucket in the water. Number four plug heavy carbon fouling. Switch the wires replace the plug and she ran great. I am just down to a fuel issue, have to use the choke to get from idle to on plane but once on plane oh it feels so good. That's why I was asking about the filter.
daselbee
Clean throttle body calibration pockets. Search my posts...plenty of them out there on this subject.
crowebar
You mentioned getting a new stator, but I didn't see that you had installed it yet. I'm assuming you did. If not, the sticky goo means yours will be unpredictable. Mine was hit and miss. Sometimes ran fine other time it only ran on half the engine. Sometimes it stalled when I punched it. I thought my magnets were fine too. they looked spaced correctly but I was able to free all but 2 with my fingers. BTW, Sharpie markers make perfect spacers between the magnets when epoxying them back in.
bgbsshntr
Yea put on the new stator and reg/rectifier. Put in new keyway key. The goo is all cleaned up and the motor sounds awesome now. The reason I feel I am down to a fuel issue is due to feathering the chock while accelerating she jumps up on plane and runs pretty darn good, she will have a little hiccup while on plane, but feel the two are both related to fuel. This has been a journey and I have learned a lot from here and all the reading I have done.
