1965 Merc110 9.8hp cylinders/plug wires
beau_cephus
I recently purchased this outboard and replaced the plugs on the engine. Question is, which plug wire goes to which plug? One of the wires from the stator has a white sleeve near the plug head. Does this go on the top or bottom cylinder?
Thanks in advance for any help on this.
The white sleeve usually has " top " on it.-----And does spark jump a gap of 1/4" or more on this motor , yes or no ?
beau_cephus
Thanks for the feedback. Looking at the manual for these, you can do a polarity check on the coil with a lead pencil approx 1/4" from the plug wire. So I assume it will jump atleast a 1/4". Is this your question?
??----Does spark jump a gap of 1/4" on each lead of your motor, yes or no.---------If not your magneto needs inspection.
tommarvin
Ensign
I think racerone means get a spark checker and test the spark,does it jump 1/4 inch, on each lead of your motor, yes or no.
merc850
Spark plug - J6C .025" gap; points .020"; max. RPM range 5000-5400.
