New boat ocean pro 150 won't start
Travismo
Ok so I just got a 20ft angler with a 96 ocean pro 150. The guy I got it from said that he was out running it one day this summer and he "smelt a wire burning" so he shut it off and all he saw was the port side temp sensor was laying down in the cowel. The boat wouldn't start after he shut it down. He stuck it back in the head but it still won't start. The motor is turning over but really slow. I just picked up the boat lastnight so I havnt had a chance to mess with it but I figured I'd come here and see where a good place to start would be.
hardwater fisherman
Turning over really slow could indicate a weak battery. Or loose or corroded battery cables.
Travismo
I currently have a charger on it trickle charging it at 12 volts and 2 amps but even if I turn it over to 60amps boost and 200amp engine start it still turns slow. The connections are pretty clean
hardwater fisherman
You could try using booster cables from a know good battery. The positive to the positive lug on the starter and the negative to the starter bracket. And see if it cranks faster.
Travismo
Well I cleaned everything up and I put a lil bit of fuel in the cylinders to see if it would fire after checking the spark. I got it to fire and run for a couple seconds then shut off. I just noticed that the top lug on the starter solenoid started smoking and got super hot. Any ideas?
Before you invest in a new starter you might want to take it off.---Take it apart and inspect it.----Ask how to do that.
Bosunsmate
You could jump to the starter directly to check whether the problem was in the battery cables or solenoid cables.
You should also remove all the sparkplugs and check the motor turns over freely with no binding
Heat means resistance. Your cables, connections or perhaps the starter brushes are not conduction the necessary electricity to turn the starter.
Also, check the entire motor and boat harness for melted wires. Those will give you problems, unless you find and fix 'em.
Fed
I'd look at the solenoid connections rather than the starter motor.
reiddo1
Sounds very much to me like the power from the battery is certainly bottle necking at the starter motor. I too believe the starter needs an examination and more than likely a cleanup and or overhaul.
Travismo
Ok so I pulled the plugs out, turned it over to blow any excess fuel out, drained the fuel filter into the pump, and it started up. I let it run for about 10 sec then shut it off so I could put the ears on it and now it won't start. It's turning but not starting. The starter sounds like it's making a grinding noise so I guess that's where I'm going now.
Travismo
Ive been messing with it and like everyone said, I'm 99% sure the starter is messed up. It's starting to grind more and more now. I pulled it off and the splines look perfectly find so it has to be internal. It's clicking now too and sometimes when I try to turn it over all it does it click. I'm not sure if it's the starter or just the solenoid. I've tried to google some info on rebuilding it or overhauling it but couldn't find anything. What should I do?
Travismo
And now the solenoid is just popping. It's not even turning the starter
Do not fear taking the starter apart.-Just some nuts and bolts !!!---Are we sure that high resistance causes heat ?
Fed
Sure fire way to find out what's happening is to check the voltage right at the starter motor while someone hits the key.
Travismo
well at this moment I'm piecing together everything to repower and rewire the boat. The wiring was an absolute mess and the battery was half way useless. I'm doing a dual battery setup with a vsr, new fuse block and switch panel. After the basics are done then I'll get back on the motor since I'll actually be able to turn the motor over and troubleshoot
Travismo
so i just put a new starter on it, turned it over and got nothing. its got spark in all cylinders and its getting fuel. I can see faintly that there is smoke coming out of the exhaust so its burning fuel to an extent but still wont start. I need to get my compression tester back from a friend but is there anything I should check?
Travismo
i checked the compression and the top 4 cylenders are 75 and the bottom 2 are at 90. I managed to get it to start and idle after pushing and holding the choke for a few seconds before turning it over with the throttle half way. a couple times it idled until I shut it off and other times itll fire then shut off immediately. ill try to dump this old fuel out and try some fresh high octane gas tomorrow.
