1967 evinrude 6hp
URELady
vintage 2 cyl 6702D evinrude, she's a champ, starts first pull, mostly.carries a load of dog 135lb yellow lab and friends for years. lost her get up and go, still starts, still runs, chugging and studdering in gear, acts like she wants to go so bad but can't, will rev in netural until I'm afraid to blow a gasket, but as soon as I shift into gear she just chugs along,I put a carburator kit in last year, rebuilt the fuel pump, but I don't think the problem is either one. I just put in new spark plugs and that didn't make any difference. Any suggestions?
flyingscott
Check for spark on both cylinders probably needs points and condensers and probably a set of coils look to make sure they are not cracked. Have you changed the waterpump lately.
oldboat1
If still boating (or maybe just running in a barrel), go for simple tests and fixes first. Insure fresh fuel, and open vent cap. Try to dial in low speed needle. Low speed needle initial setting is about 1 1/2 turns out from seated, Then try for a bit leaner (clockwise) while running at idle. Check temperature while test running (if you can hold your hand on the top of the head for a few seconds, you're not overheating. Shut it down if too hot to touch -- and watch out for the spinning flywheel.) Will want to be sure the carb opens properly during throttling up (referred to a the link and sync adjustment).
If still not doing well, do a compression and spark test (need testers for each). Look for compression in the range of 60 to 90 or so, running even between cylinders. Spark should be about half an inch (could be less). If compression or spark testing shows issues, would let that decide next steps. For cooling issues, may need an impeller or thermostat replacement (may want to just do both if they haven't been replaced in a while).***
May need to get into magneto work or revisit carb work. But do some testing first. Also would be good to get clear about timelines -- when problems started, and the order of fixes attempted.
***should mention potential gearcase issues in the mix, starting with oil change. But would work from the top down for testing.
F_R
Symptoms are classic for a motor running on one cylinder. In all probability, a spark problem. Check compression to make sure it isn't a catastrophic engine problem, and then proceed with a spark check. BTW, a half inch spark would be expected on a CD ignition, but 1/4" would be much more normal on your magneto motor.
oldboat1
fun to fool around with adjustable spark testers -- for magnetos, like to start at a half inch or maybe a little more, then work back until you see spark. Same thing with CD systems, but a little more fun -- start with 3/4 inch and work back until you get spark. With CDs in particularly, more there than you might think.
But strong at 1/4 will be good, like F_R says. To find a cylinder cutting out, I like to use a timing gun -- clamp on to individual wires while testing engine. (Need a battery for the old fashioned ones.) Check the plug gap on the new plugs (usually .030). Also make sure the spring connectors in the boots clamped on properly.
URELady
Symptoms are classic for a motor running on one cylinder. In all probability, a spark problem. Check compression to make sure it isn't a catastrophic engine problem, and then proceed with a spark check. BTW, a half inch spark would be expected on a CD ignition, but 1/4" would be much more normal on your magneto motor.[/QUOTE  Right you are, pulled plug wire and checked spark only firing on bottom plug. Pulled flywheel (itsaB) checked compression, it's about 100 on both cylinders. Now I need to know coil resistance using a multimeter or ohms meter, I'll probably change wires, clean points anything else? Check condensers? What should coil resistance be?
flyingscott
Unless the coils are cracked I wouldn't worry to much about them especially if they look replaced. Keep the plug wires unless the insulation is gone they don't go bad they are braided wire. REPLACE the points and condensers you can get them as a set and are pretty cheap. I will say this about the coils if they are original I would replace them because they will become a problem.
oldboat1
^^As discussed above, I like to replace points and condensers. Clean the points whether using the old ones or new ones. (I typically go ahead and replace coils too -- your call.)
Here's some good instruction on testing cols: http://www.penn.itgo.com/video-pages/coil-testing.html
If the wire insulation is worn or cracked, you can get arcing. In any case, the wires are easily and cheaply replaced (7mm solid core). You need good contact at the plug and the coil, and obviously no breaks in the wiring. Using a multimeter, you can check the connection from the clip at the plug end, through to the mag plate (believe that's covered in the video), and that would tell you the wiring and connections are working, at least at the point tested.
rolmops
While you are doing those things,check if the cam follower is worn down. That will influence link and sinc
URELady
Did alll the suggested tests, seems to have compression, spark, resistance in the coils. So all we did was clean the spark plugs and dropped her back in, she started up 1st pull, ran strong, took off when put in gear (original problem no umph) ran good at first, the river was running hard and by the time I got to the dock she was skipping and jerking, I just turned around and took her back out. between rain, flash floods, and Holiday, she sat until today, I figured we need to set the points since they were cleaned, but when gauged at .020 they were good, so I set up my bucket and started her, still skipping and jerking- bad, I guess I'll put a kit in, new points and condensers, but should I get new coils too?
flyingscott
I would if they look original or are cracked. If you need to put a pic up of the coils
URELady
No Title
my neighbor, whom I borrowed the pulley puller from, used pb blaster all inside my cam plate I think he got it in my points I tried cleaning them again but I can't get her running smooth, when I pull the plug wires now it stays running on either plug top or bottom but seems to run stronger on the top plug, that was the one it wouldn't run on at all, at first I'm stumped, like I said I might just go ahead and replace it all.
Does spark jump a gap of 1/4" on it now, yes or no ?----Have you done a compression test ?
Tim Frank
^^^^^^^ +1
"Seems to have compression and spark" doesn't tell anything....for all we know you might have just grounded the plugs "to check the spark" and put a thumb over the plug hole to "test compression". Use a proper spark tester and compression tester; then you know what is going on.
URELady
^^^^^^^ +1
Yes I admit, I juet grounded the plugs, but supposedly did a real test on the coils. My "helpful" neighbor, put his multimeter on them, the reading was 60/80 or 600/ 800 depending on scale. He said he didn't understand the variation from coil to coil. I told him the video suggested to use an ohms meter, not a multimeter, but I believe he took offense. He works on old motorcycles, said the set-up was very similar to his Triumph and his uas an expensive piece of equipment, not a $10 piece of junk ( I believe he was refering to my ohms meter) whatever still doesn't tell me anything, I believe he tested the continuity not the compression. After the Holiday fever passes, the rain quits, and the river clears, I plan to get back to it.
I can understand that your neighbor took offence since a multimeter has an OHMS function on it .---Turn the dial to switch between functions.
oldboat1
Get a $15 spark tester at an auto store. Make sure the clips in the boots are connected properly to the wires, and test for spark. Fool around with the multimeter some more if you want. If you get different readings between coils, just replace them both. But start with spark testing.
ddwilson
Have to agree if you are getting a difference between coils would probably replace them along with points, condensers and plugs.
