1988 Johnson 70 locked up?
Jbg1884
Recently bought an 88 stratos with a 1988 Johnson 70hp vro. Motor has ran great for 3 months until now. The vro has been taken off so I mix the oil 50:1. Anyways, going down the lake this morning everything was running good.....I was in 50 feet of water going 35mph when it felt like I ran aground. The motor shut off immediately and is now locked up and won't start. I'm new to outboard motors so what has happened? I removed the plugs and flywheel will not turn freely. Have not yet removed the lower unit. That is my next step. But when i pulled the top plug it was white and had tiny pieces of metal in the "bowl". Engine blown? What's the next steps? I am mechanically inclined.
flyingscott
Pull the lower see if that does it but i am going to guess you will need to pull the head. I am going to guess you will need to do a rebuild get the factory manual for your motor. I don't know what you mean by bowl
Jbg1884
The "bowl" I'm referring to is the bowl around where the spark comes out. Don't know the actual term.
flyingscott
Do you have the head off already or are you referring to the spark plug when you say bowl put a pic up
If you see metal bits around the porcelain you might as well pull the cylinderhead off.-----Inspect piston and cylinder wall.
emdsapmgr
The bad cyl may have been running lean. That's fatal for 2 strokes. You may want to pull the carb apart that feeds that bad cyl. Check to see if any of the jets are restricted, causing a lean condition.
Jbg1884
Well I pulled the head and piston 1 is burnt up! Metal shavings everywhere. It didn't groove up the sleeve to bad so I guess it's time for a rebuild. Anyone know how much rebuilds usually run?
Does the tell tale hose come off the side of the block or the top ?----Take it apart first to see what all this motor needs.Are you going to do this job yourself ?
Jbg1884
I would rather not. Would rather pay someone. And what is the "tell tale" hose you speak of?
Swoosh3
With two strokes it is important to check the crank bearings and seals, if a seal allows air to enter the crankcase it will
cause a lean condition and, meltdown.
If you can grab the flywheel and aggressively try to wiggle back and forth there should be absolutely no play
Worn bearings are followed quite closely by leaking main seals.
Be sure to find the root cause of the lean condition otherwise the fail will repeat itself.
Tell tale----waterpump indicator----pisser----All the same thing.----Does the hose come off the side of the block or the top ??
There was a service bulletin that came out in 1994 that strongly recommended / insisted that it be moved to the top of the block.
boobie
If you rebuild it be sure you move that indicator to the top of the block as it vents all the air out of the block.
