Challenger84
Thread starter- Joined
- May 9, 2010
- 341
So I have an addiction.
I am always looking at boats for sale.
I ran by a 1988 Bayliner with a 2005- 150hp optimax OB and trailer for under $3k.
I've been texting with the seller back and forth and says the boat does have a soft spot in the floor..
I asked about the transom and stringers as well but obviously the seller says it's "solid"
With the research and information I've gathered here, most likely transom and strings are rotted as well.. cause "boats rot from the bottom up"
I will be doing core samples to determine.
With that said..
Trailer in great condition (dual axle w/ surge breaks), engine runs like a top..
Worst case scenario i will need to restore the boat.. or dump the boat and find a donor boat with a solid hull and bad OB.
Just want your opinions to see if i should pull the trigger on this or not..
How much would a restoration cost if i sourced this out? (I won't be able to do it myself)
With that said..
