Mercruiser 470 oil coming out of weep hole ? Normal ?
kevinstan
Changed the oil in the outdrive and had both the top and bottom oil plugs out. While pumping in oil from the bottom I noticed oil coming out of the weep hole. Is this normal or do I have a problem ? No water in the oil at all but oil coming from the weep hole. What should I do ?
kevinstan
What is the easiest way to pressure test ? And if it doesn't hold pressure, how to I pinpoint the leak to fix ?
bruceb58
Either buy or make a pressure tester.
http://forums.iboats.com/forum/engin...eck-prior-post
I own this one:
http://www.firstchoicemarine.com/p-8...ester-s34.aspx
http://www.stevensinstrument.com/gearcase.htm
kevinstan
Expensive tool just to determine if there is actually a leak. With the oil coming from the weep hole I think shows there is in fact a leak. Is a pressure test still needed ? And how do I determine where exactly the leak is coming from ?
BRG25
You pump the drive up with air pressure and listen for the leak. Spray soapy water and look for bubbles.
Or...just take it to a shop and have them test it...
kevinstan
Ok that makes sense. What is the cheapest way to accomplish this without purchasing a $150 tool.
bruceb58
