Fishermark
- Oct 19, 2003
- 5,627
I am installing a Pertronix Ignitor II (Part #92842) in my 1990 AQ131. I have installed several of these in other boats I have owned and am happy with the results - but so far my experience is with Mercruisers.
I want to eliminate the resistor and need to verify what i think I understand....
On a Mercruiser the resistor is the wire itself going to the positive side of the coil which I simply eliminate. On this Volvo it appears the resistor is down by the alternator. Is that true?
If that is the case, can I simply remove the resistor and attach a wire straight from the alternator to the positive side of the coil?
Here's a pic of the resistor down by the alternator:
Here's the wiring diagram: (THE RESISTOR PICTURED ABOVE IS PART 22 IN THE DIAGRAM BELOW).
And a closer look....
