1984 johnson 115hp J115TLCRD V4 outboard overheating
Yoshidamitsu
I've looked through this forum ad all over the internet trying to find someone with similar problem. Haven't found much luck. I have an over heating issue with my johnson outboard.
I've replaced the t stats, removed the head covers and cleaned water passages, removed the heads and cleaned the water passages, replaced the water diverters inside the heads. What I'm still experiencing is the port side getting so hot you can't keep a finger on it for more than a few seconds. The starboard side is warm.
I've removed the t stats hose and started engine and water cycles just fine through both sides, keeps both banks cool, and I have a very strong tell-tale stream. This is all being ran on muff and garden hose. I only have the problem when I put the t stat hoses back on.
So it leaves me to believe I have a clog after the t stats and somewhere at the exit of the cooling system. I'm guessing this because the port side is not allowing the heated water to exit and is just building up. I dropped the foot Sunday night and will be checking the impeller and housing, but I don't think I'm going to find my problem there since that is where the water starts in the cooling system.
Am I heading in the right track? Is there anything else I should be considering?
Thank you.
oldboat1
afraid you can't tell much from running on a flusher. The first step with an overheating condition, or suspected one, is normally to replace the impeller. But you are at that point.
It's a big lower unit. Better if you try it in the lake after replacing impeller, but otherwise try in a big barrel or container -- have to be able to sink it deep, about half way up the leg. Then run it at idle, and check temps. You might be a good candidate for a laser temp gun. (Would check installation of t.stats if cooling continues to be a problem.) While you have the lower unit off, you might look up there in the leg for any obstructions, and spray up there with a hose or pressure washer. It's also effective to run water up the tubes to flush, and check circulation. Need to rig something to fit snugly around the tubes if you want to try that (fuel hose or similar), and do a low pressure flush.
sutor623
I agree, time to get an infrared thermometer. The 'Ol finger on the block is a pretty crude test...... And a properly warmed up cylinder head wont let you keep your finger on in for more than a few seconds. Lowe's has a nice infrared thermometer for under $20 that works great. The thermostat housing should be around 135-145 degrees when warmed up, and the cylinder heads themselves may be a little different than that.
I was in your same scene a few months back, one head felt nice and cool, the other felt like it was overheating. Turned out the "cooler" head was actually overcooling and the other head was great. That's the first step. Find out your exact temps. I have had thermostats right out of the box overcool my motors...........
Fed
Did you clean out the 2 little holes in the t'stat valve body?
Part # 0321693 Google it for a picture, there a a few different configurations but I think your's is the 2 hole individual type from what I can see at the BRP website.
Yoshidamitsu
Just want to thank you for the replies, help and advice.
FED: the t stats are brand new along with the gaskets, rubber rings for the poppet valves, poppet valves, and poppet springs. The t stat housing was clean of obstructions as were the t stat hoses. On the block where the t stat housing attaches I even flushed that area out, which is the exit of the cooling system. But I flushed it with the lower on an I'm sure all I did was push it down and not out. Further inspection of the exit tube with the foot off should tell me more.
Sutor623/oldboat1:
You're absolutely right and I agree. I need to get an infrared temp gun for this. I'll check out lowes. I also agree with the crude finger test. It does worry me a bit that the starboard isn't getting "hot" like it should. Possible power pack issue or plugs not firing? I'll be checking my plugs for spark in all four banks.
Thank you again for the responses. I'll update with my findings of the exit tube and impeller. As for the engine temp readings, won't be able todo that till the weekend. Only time I get to fire her up is the weekends.
sutor623
Definitely a possibility. Once you get the temp figured out you can go from there.
emdsapmgr
Follow Fed's suggestion. When you replaced the two stats, you had the valve body laying on the table. There are two pinholes toward the center of the body and both must be open to cool properly. Each of them permits a small amount of hot water to bleed thru the body to the backside where the stats are. That hot water causes the stats to open. If either of those holes is plugged (not an uncommon occurrence) that side (or both sides) of the block will surely overheat. Your engine's stats open at 143, so idle temps would be normal between 143 and maybe 155 in a warm summer lake. The hot horn sounds at 212 and shuts off when the engine gets back down to 175 degrees-still way too hot for that powerhead.
